2/17/2018 1:34 PM | |
Joined: 9/27/2006 Last visit: 9/17/2025 Posts: 12411 Rating:
Hello Rizky; If you have had no response from the forum after your first post on the subject, I suggest you use the Support Request link at the top of this page to contact Siemens technicians. There is very little information on the IP32M on the web, maybe someone at Siemens has access to older documentation that they can share. Have all the necessary information on your system ready to describe it, S5 family CPU model;, etc... so they can assign the question to the nearest specialist, if they have one. As far as your digital input and output modules are concerned, you will find technical data and wiring information in the following document (the version of the module might be a more recent version ending in -4UA13, but they are direct replacements for the -4UA12 modules, so you can trust the information).
https://support.industry.siemens.com/cs/dk/en/view/1085837 Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 2/17/2018 1:51:48 PMLast edited by: dchartier at: 2/17/2018 2:49:59 PM |
