Default Header
(0)| 7/16/2018 12:45 PM | |
Posts: 364 Rating:
Hi Experts What is the error in my code , the value transferred to DB11 not change when i change the value of the input signal AttachmentFC30.pdf (193 Downloads) |
| 7/16/2018 1:28 PM | |
Posts: 531 Rating:
There are no exits after the jump section are jumped to. The plc will always set the next section and overwrite the values?!? |
| 7/16/2018 1:42 PM | |
Posts: 364 Rating:
Where do i need to put the extra commands to fix it? |
| 7/16/2018 1:51 PM | |
Posts: 531 Rating:
After the jump and setting of the value there should be an end of fc command or at least a jump to a mark at the end. |
