(0)| 8/20/2018 9:55 AM | |
Posts: 3 Rating:
Thank you for your reply. It did help a little bit. What I have found so far: The switch must be in the RUN-P position. When the switch had been changed I needed to close the LAD/STL/FBD editor and reopen it again. I also needed to go to: debug / operation on the menu. I don't need to (or more precise I cannot change anything here), But it seems necessary to go here anyway and press the OK button. Now I finally had the menu option: Monitor with call-up path But I got a new problem : When I click on monitor with call-up path, it does open the other function, FC102, but I get this error message: (D0A9) Job cannot be read because it is currently being deleted, for example. Try again. This happen every time I try. ------------------------------------------------------------------------------------------ |
Last edited by: Sven-Ake at: 8/20/2018 12:50:49 PMLast edited by: Jen_Moderator at: 8/20/2018 2:37:01 PMNew subject after splitting. Division of questions into separate topics. |
