(1)| 9/7/2018 4:05 PM | |
Posts: 14 Rating:
I do have some problem generating F-DB's for the F-DI and F-DO units. After adding the units in the HW-configuration - pressing "safe and compile" - it should happen automatically, right? It does not. I do not see and F-DB's generated by the program. I did read through the S7300_GS_e.pdf and tried to follow their setup, as far as my modules allow. Attached please find screenshots of my setup. Maybe that helps to figure out my problem. I certainly did something wrong, but I can not figure it out. Thanks for your help in advance. Regards, Woodfritz AttachmentSM_TEST_ERR2.pdf (183 Downloads) |
| 9/10/2018 6:05 PM | |
Posts: 14 Rating:
Exactly as you said, Hati. Thanks so much. Cheers, Woodfritz |
