Default Header
(0)| 8/27/2008 5:52 AM | |
Posts: 487 Rating:
Hi Speaking under correction RS8 RS9 RS10 is the real time clock on a 115U . Tell is where is it used and on what PLC type ( ie OB22 on a CPU942) Download the manual at the following link see chapter 13 Eric |
| 8/27/2008 6:07 AM | |
Posts: 19 Rating:
Hi Eric, Its in FB200 on S5-95U. Thank you. Zul |
| 8/27/2008 6:30 AM | |
Posts: 487 Rating:
Hi ok , check this link its the S5 095 manual , look at appendix B13.It has to do with the real time clock .In these RS you define where the PLC mustput for the real time clock info.There are similar functions for S7 Have a look at the following thread Eric |
| 9/16/2008 3:47 AM | |
Posts: 19 Rating:
Thanks a lot. Appreciate that! |
