(0)| 11/22/2018 10:46 AM | |
Joined: 11/9/2008 Last visit: 12/8/2025 Posts: 414 Rating:
Hi All, I need help regarding FIFO logic. I have create data base to store data in data block. I able write data in data block also reading the store value in ascending order. E. g 1, 2, 3,4,5,6 up to 96 Buffer. Now I want read value again in descending order from 96,95,94,93 up to 1. I have tried logic for the same but facing problem to read value in descending order E. g values of index 5 not showing properly its shows index 4 values in final result. For reference please find the attached PLC backup. In PLC backup I have created VAT table nameFIFO_VIEW, M 59.0 is used to start FIFO. Every 10sec data will be log in DB123. M 400.1 is Read data log in ascending order and M 400.2 is to read data in descending order. Please check program guide me. Regards, Yogendra AttachmentTest.zip (187 Downloads) |
| 11/26/2018 8:47 AM | |
Joined: 12/13/2011 Last visit: 10/1/2024 Posts: 146 Rating:
Hi, I have the version with the s7 programs. I give my example. AttachmentPictures.zip (229 Downloads) |
