Default Header
(0)| 9/30/2008 3:16 AM | |
Joined: 9/27/2006 Last visit: 12/26/2025 Posts: 12474 Rating:
Hello Hbosquemx; There is no single compatible function block for such a conversion. You have to install the new FBs that come with the new modules in your new Step 7 program, converted from the S5 program without the IPxx blocks. Which means you have to look up the manuals for the new modules and study them, as a first step. For the FM 450: -Getting Started: http://support.automation.siemens.com/WW/view/en/5574978 -Installation and configuration: http://support.automation.siemens.com/WW/view/en/1118412 For the FM 453: -Getting Started: http://support.automation.siemens.com/WW/view/en/2124818 -Manual of the servo/stepperpositioning module: http://support.automation.siemens.com/WW/view/en/2123608 The Getting Started manuals are a good place to start, they are short, general, and give a good overview of the installation, parameter assignment and functions required to make the module work. The other manuals are more heavy reading, but they cover most details of the workings of the modules. Especially important if you have to chose different configurations or applications with these modules. There are many documents available on every Siemens module on their support page: FAQs, Application notes, downloads, updates... can be found on the Product Support link at the top of this page. Simply use the Search window in the support page to look for inofrmation on the FM 450, for example. And of course on this forum you will find other control people who have had experience with these modules, and who can help you out when you face specific problems. Suerte y paciencia, Hope this helps, Daniel Chartier |
| 9/30/2008 11:28 PM | |
Joined: 9/1/2005 Last visit: 10/31/2025 Posts: 4114 Rating:
closed cause question posted more than once. The thread with all replies is published with the subject Help to converter project from S5 to S7within the conference SIMATIC S7. Best regards CS Moderator |
