(0)| 12/16/2016 9:37 AM | |
Posts: 236 Rating:
Hello, I tried example of writing one DB to another through pointers. I've used the example 2 from this topic: I write to the inputs number of sourse DB and number of destination DB, but it doesn't work. But I the FB is not active. In Value table I can see that DB5 "can't be monitored". What is wrong?
I attached screenshots below. AttachmentScreens_16.12.16_10-36-14.zip (348 Downloads) |
Last edited by: KCD at: 12/16/2016 9:37:57 AMLast edited by: KCD at: 12/16/2016 9:42:37 AMLast edited by: KCD at: 12/16/2016 9:57:51 AM |
| 12/16/2016 9:53 AM | |
Posts: 5521 Rating:
hi KCD, Is the FB and the DB loaded? Can you monitor the FB22? Does the BLKMOV give any Error in Ret_Val? regards, |
