(0)| 3/29/2019 6:51 PM | |
Posts: 7 Rating:
Hello, I use w'ndows 2000 and simatic step 7 5.2 version. I installed Harware package but at the end of this process some errors appeared. Then simatic didnt open again. Could you advice me what could be possible reasons of this situation. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 4/1/2019 7:17:01 AMNew subject after splitting |
| 4/5/2019 10:42 AM | |
Joined: 10/10/2005 Last visit: 1/29/2025 Posts: 1940 Rating:
Hello Robust, have you an error message, if you try to open the SIMATIC Manager, example internal OLE error? Create free space on the hard disk (>100MB) and set the virtual main memory to user-defined (information on this is available in the STEP 7 readme file). See also the information of the FAQ: With best regards |
| 4/8/2019 1:56 PM | |
Joined: 9/27/2006 Last visit: 1/1/2026 Posts: 12479 Rating:
Hello Mr. Robust; And did this new installation correct your problem? Hope this helps, Daniel Chartier |
