(0)| 4/30/2019 9:00 AM | |
Posts: 8 Rating:
Dear Experts, We have IPC 847D servers with following configurations. MLFB : 6ES7660-6HM71-3FD6 System SW: PCS7 V9.0 SP1 Red. OS Servers with MS Server 2016 RAID 1 : 1 TB (2 x 1 TB HDD, mirror disks), RAID controller onboard + 1 x 240 GB SSD (for operating system) ------------- New requirement is to have RAID 5 Configuration. RAID 5: 2 TB (3 x 1 TB HDD, striping with parity), RAID controller on board + 1 x 1 TB HDD as hot spare ------------- 1. Can we upgrade to this required Configuration by adding additional HDDs & removing SSD ...?? 2. If we can upgrade to required configuration, please provide detailed document of procedure & basic requirements. 3. Can we add Hot Swapping functionality into this Hardware with required RAID 5 Config. .?? please go through attached IPC 847D document for ref. Regards, Henish Chahwala AttachmentSIMATIC IPC847D.pdf (463 Downloads) |
Last edited by: Henish_STME at: 04/30/2019 09:37:14Last edited by: Henish_STME at: 04/30/2019 10:02:11Last edited by: Henish_STME at: 04/30/2019 10:03:44 |
| 4/30/2019 11:29 AM | |
Joined: 10/18/2012 Last visit: 12/1/2025 Posts: 225 Rating:
Dear Henish_STME, IPC847D specs can be found here: https://support.industry.siemens.com/cs/ww/en/pv/6AG4114-2....-..../td?dl=en. According to this "RAID5 (3x 1 TB HDD, striping with parity) + 1x 1 TB HDD as hot spare" is possible for this IPC type. I would recommend you to get in contact with your local Siemens representative for further steps. See https://www.industry.siemens.com/aspa_app/?lang=en. regards,
