(6)| 11/24/2014 8:14 AM | |
Joined: 1/28/2009 Last visit: 12/26/2025 Posts: 6889 Rating:
Hello Guybrows83, The sign regarding a positive or negative number is included while you convert INT to STRING with FC16(I_STRING) from IEC library. As an alternative, you can convert the input as INT to the BCD equivalent and then use HEX to ASCII conversion "FC95(HTA)" from TI-S7 converting blocks.In thiis case the positive sign has no meaning.A sample can be found here: https://www.automation.siemens.com/tf/WW/en/Posts/107469 The other strategy would be checking if possible to manipulate the output STRING before sending it to the printer. I hope this helps, Hamid Hosseini |
| 2/18/2019 9:58 AM | |
Posts: 1 Rating:
Thanks it works... |
| 5/23/2019 1:10 PM | |
Joined: 6/26/2017 Last visit: 12/12/2025 Posts: 4 Rating:
You can also use the VAL_STRG() to convert a numbers into strings. |
