(0)| 9/6/2015 6:40 PM | |
Joined: 6/19/2013 Last visit: 11/21/2025 Posts: 15 Rating:
Hello, Thank you for your response. I have detailed the steps I take to try and install SP4:
Step1. I select the .exe file downloaded from Siemens labelled simatic_step7_v55_sp4.exe. I follow the instructions.
Step2. I change none of the options, here and allow for the extraction to be carried out within the temp directory, then press next.
Step 3. Program begins extraction (what I tried to describe in my earlier post).
Due to previous attempts to install, some files still exist on the OS, I just overwrite them all.
Once extracted to the temp directory the setup is executed and instantly we get the "Setup: Can't initialize the objects!".
I Press OK, and then.... Nothing. If anyone has seen this before and can offer any advice, it would be a great help. I have the .GSD files for the ET200SP Modules I am working with, I just need SP4. Best Regards Gavin3000 AttachmentSteps.zip (414 Downloads) |
Last edited by: Min_Moderator at: 9/7/2015 10:08:22 AMMove Pictures in attachment |
| 9/6/2015 7:01 PM | |
Joined: 5/12/2006 Last visit: 12/19/2025 Posts: 22816 Rating:
Hi, have you try to extract the files to anither shorter path? You can try to download the SP4 Setup directly from here: https://support.industry.siemens.com/cs/ww/en/view/93842624 This is the uncumpressed setup for the SP4, an not the WebInstall which you use. Regards Christoph |
| 8/31/2019 6:50 AM | |
Joined: 3/20/2009 Last visit: 1/31/2020 Posts: 1 Rating:
Hello, do you get a solution from customer support ? |
