Default Header
(0)| 3/7/2020 1:10 AM | |
Posts: 3 Rating:
Good night, I'm using the siemens s7 1500. However, I'm having errors. The PS is flashing green (top left) and the CPU is flashing red. I saw that you already saw and solved this problem. I would like you to give me more information about this solution. I've been trying to solve this problem for some time. Thank you very much in advance. Please help me. Below is the error: CPU error: hardware configuration error: Option note compatible with device configuration Work interrupted, New satartup inhibit set: ... To measure the pending allocation error ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/09/2020 06:01:18New subject after splitting |
