(3)| 5/18/2020 5:40 AM | |
Joined: 2/5/2013 Last visit: 1/5/2026 Posts: 330 Rating:
Hi JL 99, You can check CPU error in diagnostic buffer. Select CPU and press short cut key Ctrl+D for diagnostic buffer. Br, AmolG. |
Last edited by: Jen_Moderator at: 05/18/2020 11:33:32Optimized link. Please rate it. |
| 5/18/2020 6:28 AM | |
Posts: 83 Rating:
Hi AmolG, Thanks for reply. regards to my 2nd question? Is it normal that you will see other SFC,SFB, FC, FB and DB when you download and go online? |
| 5/18/2020 6:35 AM | |
Hi JL99, Yes it is normal. It will shows blocks in Load Memory (Memory Card) after downloading program in CPU. e.g Function ,Function Block and Data base. Also System Function and System Function Block and System Data base present in online CPU. Br, Amol |
