1/26/2009 10:16 AM | |
Posts: 24 Rating:
Dear all, i Would like to ask if this programe can i use it for download and editing program, i allready know that the program which should i use to program Step 5 is software under DOS but the program which i ask you about it its work under windows as following picture. please if you have the program which it work under DOS, take printscreen for me or give me the full name of the program and where can i buy it or find it. also i want the order no. of the programming cable. FInally Thank You AttachmentStep 5.zip (468 Downloads) |
1/26/2009 11:46 AM | |
Joined: 3/21/2006 Last visit: 3/30/2025 Posts: 10239 Rating:
Hello For programmingStep5 controller use Step 5 software. You can order it from Siemens office in your place: 6ES5894-0MA04 STEP 5 BASIS V7.2, CD, SL, (G/E/F/I/S) For connection PC - Step 5 PLC you need S5-PC converter TTY - RS 232 is MLFB 6ES5 734-1BD20. If you don't have serial port on PC, look at some S5 PG-USB. My advice is to use Step 5 software.(Windows not DOS version) Perhaps this is useful Compatibility of STEP 5 versions with Windows operating system Sorry I can't open your attachment, but maybe you are asking about PG2000. |
1/26/2009 1:14 PM | |
Posts: 24 Rating:
thank you dude a lot i have allready serial port so i will use serial cable finally thanks a lot for your information You help me a lot |
1/26/2009 1:32 PM | |
Hello You are wellcome. By the way, S5 Simulation /SoftPLC 1.67 is very interesting... regards |
