5/31/2017 4:44 PM | |
Joined: 3/17/2014 Last visit: 7/30/2025 Posts: 53 Rating:
Hi all, I'm trying to install s7 and opcua nodes for a customer that doesn't have a internet connection.So I had: -download the node from https://github.com/netsmarttech/node-red-contrib-s7 -renamed the folder into node-red-contrib-s7 -moved it into /usr/lib/node_modules And seems to run correctly. Instead for OPCUA node the same procedure does not works. Do you have any suggestion? What is the right procedure in order to install nodes without connection? Thank you |
