Default Header
4/26/2007 4:24 PM | |
Posts: 39 Rating:
Dear pandora303, with the numerator/denominator ratio will be fixed the gear direction. That means: 1/1 or -1/-1 = 1 à Following axis follows in same direction -1/1 or 1/-1 = -1 à Following axis follows in opposite direction Synchronizing direction means the direction of the following axis when synchronizing to the master axis. That means for your case: Master axis moves negative; Following axis follows in the same direction. à You must select a gear ratio 1/1 or -1/-1 and synchronizing direction = negative. |
