3/11/2015 7:38 AM | |
Posts: 1299 Rating: (135)
Hello, 1 hour is the maximum of user define cycles which you can use in the scheduler. https://support.industry.siemens.com/cs/mdm/109096785?c=52264355211&lc=en-WW But you can use the 1 hour trigger and invert a bit first. Only if the bit is 0 you execute the script.
K!ke |
Last edited by: K!ke at: 3/11/2015 7:39:02 AMLast edited by: K!ke at: 3/11/2015 7:39:38 AM |
