8/31/2015 5:53 AM | |
Posts: 62 Rating: (0) |
I use attached file in my program,it is your attached file in other comments(I wanna know when DP Slave has a failure - OB86It works good for one time in my program,it means when I download my program,and create a fault in one salve ,it detect it correctly,but when rack returns or I have failure in another slave,SFC51 doesn't have any change while OB86 detect master fail and work correctly.AttachmentOB86.pdf (125 Downloads) |
8/31/2015 9:25 AM | |
Joined: 1/28/2009 Last visit: 4/1/2024 Posts: 6836 Rating: (1359)
maybe,I should create a positive edge for "REQ" input of SFC51? Check the idea discussed in the following link,It is possible to request SFC51 on a cyclic manner like:
Issue related to OB86 call after CPU startup in case of DP Slave failure
9/1/2015 8:22 AM | |
thanks to be kindly,I send my project to you. Hardware has difference with symbol table lead to my hardware assembled in my workshop.and HMI delete lead to decrease size. AttachmentSefid_da.zip (108 Downloads) |
