12/20/2017 5:47 PM | |
Joined: 11/5/2012 Last visit: 8/10/2024 Posts: 487 Rating: (63) |
Hello Pablo. Is called Multi instance, you know FBs require a DB to work because they have static memory, right? Basically multi instance allows you to "insert" small FBs memory areas inside a bigger Instance DB memory area, this way you can use the same IDB and run several FBs inside an FB from which IDB is created. I'm not good at explaining but here you can see come explanation of that. And I found on the forum someone who posted this images that illustrate it. Hope this help and answer your question. AttachmentMultiple Instance.zip (77 Downloads) |
