7/17/2018 12:05 PM | |
Joined: 10/11/2006 Last visit: 4/26/2024 Posts: 5824 Rating: (789)
Hello, check your encoder. Is zero mark available? If yes, check correct wiring and parameterization. 4.6 Encoder 5.7 Function parameters - "Encoders and drives" tab 6.3 Incremental encoder (TTL) https://support.industry.siemens.com/cs/ww/en/view/35014863 |
With best regards, |
7/18/2018 10:56 AM | |
Posts: 5 Rating: (0) |
I checked zero mark on encoder with osciloscope. They work well. Wiring and parametrization i did from manual. What else could be the problem? |
7/18/2018 1:05 PM | |
Hello, search for the reason of the fault on IM174 side. 7. Interrupt, error and system messages https://support.industry.siemens.com/cs/ww/en/view/35014863 |
7/18/2018 2:01 PM | |
0x100h zero mark monitoring of encoder |
7/19/2018 1:08 PM | |
And what to do of this? How to disable zero mark monitoring without bridging? ...sent from App |
