12/10/2018 4:43 PM | |
Posts: 23 Rating: (0) |
No, no spare reader avaiable. |
12/10/2018 5:40 PM | |
Joined: 10/1/2013 Last visit: 5/8/2024 Posts: 605 Rating: (71)
Attached you'll find the project I used. I basically just swapped the PLC. Even though I had a RF310R it also worked with RF380R in the TO configuration. So your problem must be caused by the cable or the reader. Edit: Is your RF180C shining green or blinking green? Attachment18.056 Carico e Scarico Manuale OP45 siemens.zip (276 Downloads) |
Last edited by: Owei at: 12/10/2018 5:41:51 PMLast edited by: Owei at: 12/10/2018 5:42:43 PM |
12/10/2018 5:47 PM | |
Before the reset comand on the 120c both the 24V and DIAG led are green, no blinking. |
12/10/2018 5:50 PM | |
Ok. In this case it must be reader/cable. |
12/10/2018 7:04 PM | |
Would be nice if you share the outcome of this support request. |
12/11/2018 1:06 PM | |
It's always just array of byte. |
12/11/2018 3:13 PM | |
Cable checked today, seems ok. but error still remain. |
12/12/2018 2:56 PM | |
In this case it should be the reader |
