5/8/2021 3:53 PM | |
Joined: 9/27/2006 Last visit: 5/9/2024 Posts: 12257 Rating: (2666) |
hello jerahmeel; I am afraid we need nore detailed information before we can suggest any tests or solutions to your problem. Which version of PCS 7 are you working with? What model/part number of S7-400 are you deploying? When you speak of server redundancy, o you mean ES redundancy (on the PLCs) or OS redundancy (on the WinCC SCADA side)? When you say you transfered from server 1 to server 2, how did you proceed? Have you looked at the diagnostic files of your servers? For the s7-400, they are located in the diagnostic buffer of the CPUs, for WinCC you could open WinCC_sys.log and WinCC_SSrtart.log:
https://support.industry.siemens.com/cs/ww/en/view/13076572
https://support.industry.siemens.com/cs/ww/en/view/11965771 Hope this helps, Daniel Chartier |
5/10/2021 4:49 AM | |
Posts: 2 Rating: (0) |
Hi Daniel, Thank you for your reply. We are using PCS7v8.2. We are not deploying new controllers. We have OS redundancy. When we stopped the services of server 1 it transferred to server 2 then the plant shutdowns. Thanks for the information. Will check for the logs. Regards, Jerahmeel |
