8/4/2021 6:06 PM | |
Joined: 11/8/2018 Last visit: 4/23/2024 Posts: 81 Rating: (0) |
Old is 6ES7 315-2AG10-0AB0 New is 6ES 315-2AH14-0AB0 |
8/5/2021 7:04 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872) |
Please refer below FAQ. Please note, back up all data of present MMC & keep it in other folder so in case you can have original data. How can you load projects to a memory card and back again to a PG/PC? Which devices can you use to read from, write to or delete from an S7-300 MMC (Micro Memory Card) outside the CPU? |
8/5/2021 7:26 AM | |
Thanks for your reply but where should I connect the USB programmer on the profibus connected to the DP or MPI ? |
8/5/2021 9:00 AM | |
Joined: 5/28/2008 Last visit: 4/15/2024 Posts: 4505 Rating: (835)
Do you have SIMATIC manager? Do you have a PC Adapter? Which Part number? |
Ayman Elotaify |
8/5/2021 9:39 AM | |
So the problem was solved by connecting the usb programmer to MSI instead on the profibus Thanks all for you input |
