8/17/2021 12:38 PM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating: (2145) |
Hello Vahid08, see the manual: https://support.industry.siemens.com/cs/ww/en/view/109795092/144222496395
Georg Berghof |
PS: If this post did really help you, you may use the Rate-button |
8/18/2021 2:54 PM | |
Posts: 198 Rating: (60) |
Hello Vahid, Since it is a main version upgrade of PCS7, there will be significant changes in the faceplates, block libraries, block icons, features and functionality. I've attached the 'What's New documentation for 9.0 SP2' with this reply. It will help you to understand the major changes. Apart from this, it is also important to consider the migration/upgradation if you intend to migrate from 8.2. You can consider either of these procedures depending on whether or not to retaining the functionality of the older version of PCS7. https://support.industry.siemens.com/cs/us/en/view/109767558 https://support.industry.siemens.com/cs/us/en/view/109767557 Hope this helps. Attachmentwhatsnew_en-US (4).pdf (144 Downloads) |
