9/25/2021 2:26 PM | |
Joined: 9/27/2006 Last visit: 9/24/2024 Posts: 12282 Rating: (2685) |
Hello Aivaras; Based on the error message you show, t seems simething is wrong in the definition of your connection on the ET 200SP CPU. Suggestion: Look at the following document, detailing the communication setup between different S7 PLCs, for PUT/GET. The second section discusses S7-300 and S7-1200 projects, which should be very close to your ET 300SP CPU. https://support.industry.siemens.com/cs/ww/en/view/82212115 Follow the document hints for setting the connection on the S7-1200 and modify your project accordingly. Hope this helps, |
