10/24/2021 6:27 AM | |
Joined: 1/11/2019 Last visit: 4/23/2024 Posts: 684 Rating: (139) |
Hi A.Eslami, I couldn't give you the solution as we have not come across of this kind problem so far, You can create a service request for the same using below link Create Service Request (Use this online form for specific solution suggestions or send your technical question directly to a product specialist in the Technical Support). Hope it helps you! |
10/24/2021 9:11 AM | |
Joined: 4/6/2021 Last visit: 3/24/2024 Posts: 4 Rating: (0) |
Hi Mr.Taru, Thanks for your guidance As you said,I will use Create Service Request. Best Regards |
10/25/2021 3:33 PM | |
Joined: 3/14/2008 Last visit: 4/26/2024 Posts: 2066 Rating: (927)
I doubt it's relating to your CPU firmware. One thing I can think of is that your PIP settings are messed up and your OB's are running with a different PIP. Can you show the PIP settings from the hardware configuration and a screenshot of the timer block with the SampleTime visible? Also list the OB where the timer is called. |
