1/25/2022 5:38 PM | |
Joined: 12/18/2014 Last visit: 9/21/2024 Posts: 33809 Rating: (4200)
Import of a technical question of the user LuuTun via PM. ----------------------------------------------------------------------------- Hi Ixo65. I need your help. AttachmentAlternationTest_V2.zip (811 Downloads) |
1/25/2022 6:50 PM | |
I hope I understand you correctly.
AttachmentAlternationTest_V3.zip (848 Downloads) |
1/26/2022 4:06 AM | |
Hello LuuTun, you're welcome ... |
5/23/2022 2:52 PM | |
Try this.
AttachmentAlternationTest_V4.zip (667 Downloads) |
5/24/2022 4:24 AM | |
Joined: 9/7/2021 Last visit: 10/18/2023 Posts: 52 Rating: (0) |
Sorry for not being clear. Now I want to continue developing this diagram and add 2 solutions. The problem arises when float 2 works 2 pumps will run and when float 2 stops pump 2 stops but 2 pumps no longer work alternately from time to time, now I need your help, i would like to suggest 2 solutions: Solution 1 is after float 2 disconnects then pump 2 stops and 2 pumps keep taking turns in time and solution 2 is after float 2 disconnects, 2 pumps will run until float 1 interrupts and cycle will start from the beginning. Currently I have not found a workaround. Looking forward to your help. Thanks a lot AttachmentAlternationTest_V3.zip (670 Downloads) |
Last edited by: LuuTun at: 05/24/2022 04:27:22Last edited by: LuuTun at: 05/24/2022 04:28:31 |
