Industry Online Support
5/17/2009 3:05 PM | |
Joined: 9/27/2006 Last visit: 5/9/2024 Posts: 12257 Rating: (2666) |
Hello Rasool; I have not worked with Teleperm M myself, so I can only provide youwith links to the PCS 7 Migration site, and toinformation on the migration philosophy located in the Siemens support webpage. I hope you can find answers to your questions by yourself: PCS 7 Migration site: Teleperm M https://pcs.khe.siemens.com/index_teleperm_m-7423.htm also: https://pcs.khe.siemens.com/index_teleperm_m-1204.htm Manual: Migration TELEPERM M - SIMATIC PCS 7 PCS 7/TM Technical Description http://support.automation.siemens.com/WW/view/en/18323873 Hope this helps, Daniel Chartier |
5/18/2009 5:44 AM | |
Hello Rasool; As I stated earlier:
Whatever information is in the documents available from the site is the best I can propose.If you cannot find documentation on the exact modules you have in your project, I respectfully suggest you contact Siemens Process Control Engineering or Technical Support. You could look at the Local Contacts page on the PCS 7 website mentionned earlier. Hope this helps, Daniel Chartier |
