2/24/2015 2:24 PM | |
Posts: 567 Rating: (106) |
Hi RaviS, check your terminal bus connection if there is a valid IP address.
4/27/2015 9:32 AM | |
Hi RaviS, please check the following points: - terminal bus adapter is at the first position in the advanced network settings - the user have to be the some which is logged on the ES and on the OS server (same user name and password) You can find some more information in the PCS 7 compendium part A at the chapter 3.3.5
12/11/2017 12:14 PM | |
Joined: 6/19/2017 Last visit: 4/23/2024 Posts: 7956 Rating: (162) |
New question published by EdilsonH is split to a separate thread with the subject Tried to start the SQL SERVER and it gives the message 'The request failed or the service did not respond in a timely fashion. Consult the event log or other applicable error logs for details'. Best regards |
Last edited by: Jen_Moderator at: 12/11/2017 12:16:36 PMInserted right headline. My Forum is the place to personalize your profile, |
