5/5/2015 2:12 PM | |
Posts: 4 Rating: (4) |
WinCC Flexible Error: cannot connect to configured SQL server Solved !!! (For 2008 SP2. Windows 7 Ultimate) With: 1) Close WinCC Flex in the taskbar %USERPROFILE%\AppData\Local\Microsoft\Microsoft SQL Server Data\WINCCFLEXEXPRESS 3) Delete the whole \WINCCFLEXEXPRESS library. Restart WinCC Flexible project. And corrupt library will be rebuilt. see detailed procedure in: https://support.industry.siemens.com/cs/document/29420407?lc=en-WW |
7/14/2015 10:35 AM | |
Posts: 1 Rating: (0) |
Thank you very much Your method solved our problem
