10/6/2015 12:55 PM | |
Joined: 4/1/2013 Last visit: 9/12/2024 Posts: 61 Rating: (3) |
Hi Body! Is changing the runtime instances possible for two wincc flex projects with diferent IP address? Thanks, ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 10/7/2015 2:59:39 PMNew subject after splitting "Never take advantage of others, but don't let others take advantage of you" |
10/9/2015 5:22 PM | |
Joined: 5/28/2008 Last visit: 9/9/2024 Posts: 4515 Rating: (839) |
Hello, Please tell us more details. How many PCs you have? Do you want to control one system from two different PCs using two WinCC flex projects? |
Ayman Elotaify |
10/25/2015 8:45 AM | |
Hi Ayman! We have 10PC's. Yes, I want to control one system from two different PCs using two wincc flex project. Is is posibble? :) |
10/25/2015 10:23 AM | |
Hello, In principlem yes you can control one system from more than one PC / Operator Panel. Each PC / OP will have its project. Practically, Each CPU have limits on the connections. For instance, For CPU 312; 6 Connections & For CPU 315-2DP: 16 connections. Hope this helps. |
Ayman Elotaify |
