2/13/2016 7:10 PM | |
Joined: 10/21/2008 Last visit: 8/12/2024 Posts: 8 Rating: (0) |
TIA Updater page |
2/13/2016 7:25 PM | |
Posts: 5225 Rating: (1192)
Essentially the Italian message is complaining about a version miss-match. Probably there is some components of TIA Portal that is not updated properly. Did you hope to update from update 2 to update 7? Please publish what software is currently installed on your computer.. Also have a look at: Good luck. |
Last edited by: William_B at: 2/13/2016 7:27:04 PM@Christoph: I did not see you reply until now. I'll leave this thread for you. |
2/14/2016 4:04 PM | |
Hi William, you are true, as the message says, there is a mismatch between : Totally Integrated Automation Portal V13 SP1 Update 7 and STEP 7 Professional V13 SP1 Update 2 The problem is that this message comes after the installation of TIA Portale Update 7 (from the link you suggest) and there is no way to update only STEP 7 Professional!! Now the system is unusable, it's not possible to run TIA Portal or uninstall the update 7. Probably I need to reinstall all the software starting from a clean system. I think that TIA Portal is far away to be a usable system!!
2/14/2016 4:49 PM | |
I tried German and English, the message is always the same. |
2/15/2016 3:09 PM | |
no other idea or workaround to solve this problem? |
