4/19/2016 7:21 AM | |
Joined: 4/25/2011 Last visit: 9/18/2024 Posts: 128 Rating: (5) |
Hello, Make sure you have configure pg/pc interface correctly, PING can work with wrong pg/pc setting also(it is a windows tool not a siemens). If pg/pc is complete than go to prosave and check the version of your device. here it must communicate if all setting are correct and if not than share screen shots of pg/pc setting and prosave setting with errors. you can use attached pictures for reference. Thanks & Regard's Attachmentpg-pc setting.zip (237 Downloads) |
