5/11/2016 3:01 PM | |
Joined: 6/4/2010 Last visit: 4/12/2024 Posts: 370 Rating: (125) |
Dear Balajirajendran, Thank you for your question. Siemens has a wide range of HVAC and Building Automation controllers for different purposes, like room automation, primary control, chiller applications, OEM, etc. There are freely programmable controllers, pre-programmed devices, with various communication protocols and a wide range of application libraries and tools. One part of the controller range can be found in the system catalogue under the following link: https://www.downloads.siemens.com/download-center/Download.aspx?pos=download&fct=getasset&id1=A6V10387472 Other controllers can be selected in the HIT tool: http://www.hqs.sbt.siemens.com/gip/general/linkmapper/Linkmapper.aspx?application=HIT&language=en&domain=HQEU&module=Product&Submodule=ShowGroup The picture provided does not show the controller type. We would also need detailed information about the I/O usage, programming option and required communication protocol and/or system integration for an advice. We recommend to contact your local Siemens BT sales office. They are glad support you and to advise you for the best possible solution for your specific use case. Best regards, Albis |
