5/24/2016 9:27 PM | |
Posts: 84 Rating: (8) |
Hello, What are the possible reasons for a periphal access error to an ASI slave through an IE/AS-Interface LINK PN IO ?? Regards |
5/25/2016 9:04 AM | |
Joined: 8/31/2013 Last visit: 4/18/2024 Posts: 606 Rating: (41) |
Hello You can put an print our screen to your status |
Warm Regards |
5/25/2016 10:08 PM | |
Hello, This is a screenshot of the cpu buffer diagnostics. the slave adress is 13A. Regards |
5/28/2016 1:45 PM | |
What is the Version of TIA portal did you use ? |
Warm Regards |
5/29/2016 3:45 PM | |
Hello, I'm using TIA PORTAL V13 SP1 with update 8. Regards |
5/29/2016 4:18 PM | |
Hello Did you Update the Software Packages of Tia Portal ? |
Warm Regards |
