7/30/2016 2:30 PM | |
Joined: 9/27/2006 Last visit: 9/20/2024 Posts: 12282 Rating: (2684)
Hello CHITZ; The following document presents 3 options for writing a program from a S7-400 PLC to a memory card. How can you write the program to the FLASH Memory Card when using a SIMATIC S7-400 CPU? https://support.industry.siemens.com/cs/ww/en/view/23670531 The first requires a prommer, either as part of a Siemens PG or as an external add-on (to be purchased). The 2 last options require no additional hardware (you start by slotting the memory card in the CPU memory card bay), but have each their own peculiarities:
Hope this helps, Daniel Chartier |
