1/20/2015 5:20 AM | |
Joined: 1/28/2009 Last visit: 4/1/2024 Posts: 6836 Rating: (1359)
Hello mehtabahmed, Practical tip for using "Midline Output " is only to copy the RLO result of an extensive ladder logic, save it in a global memory ,or a local memory, and use it in rest of your block. This save you repeating the whole complex logic, save the memory required for code section and make the program neat and more readable. In your case, you wrote the content of RLO before this instruction to an input that is totally wrong.Check the attached file. I hope this helps, Hamid Hosseini Attachment15.zip (327 Downloads) |
