7/20/2017 11:52 PM | |
Joined: 7/7/2010 Last visit: 9/20/2024 Posts: 15213 Rating: (2417) |
I cannot think of the elegant way I would want to do it... By loading a EAN128 FONT into an HMI, and then use that font to display bar-code data. However, you can simulate this behavior using IMAGES taken from screen grabs from your PC after installing an EAN128 barcode font. Then name each of the images that represent parts of the EAN128 bar code and then display the images side by side with no space and fixed width. This web page ( http://www.keyence.com/ss/products/auto_id/barcode_lecture/basic/code128/ )seems to contradict your post's example barcode data. Please look at it and post a reply. I suggest a more advanced HMI so you can load a custom font to handle the bar code so you can just point the bar code at your string tag within the db, and it then displays the correct bar code for that string.
science guy |
7/21/2017 9:34 AM | |
Posts: 4 Rating: (0) |
I have loaded a code128 font into the HMI. Do you know if it is just enough to calculate the string, and then just put it up on the screen in code128-font? |
7/24/2017 8:55 AM | |
Didn't work . I mis some control characters I guess. Have to do some more research. Or does anyone did it already and is willing to help? Thanks anyway. |
7/31/2017 11:07 AM | |
Posts: 648 Rating: (95) |
Dear taco,
Do you know the "Toolbox for HMI Projects"? The you can find a detailed describiton https://support.industry.siemens.com/cs/ww/en/view/106226404 With best regards rh1990 |
9/28/2017 9:13 AM | |
Thanks Guys, it works like a charm.
