9/13/2017 9:06 AM | |
Joined: 6/30/2014 Last visit: 5/13/2024 Posts: 456 Rating: (86)
Good day Dinesh, I'd like to suggest to follow the steps mentioned in this FAQ. All the very best, SuperPippo |
9/13/2017 9:18 AM | |
Joined: 1/24/2013 Last visit: 7/19/2022 Posts: 226 Rating: (42) |
Thanks for quick reply, Superpippo... Will update the result in forum once i tried with Debugview. -- Regards Dinesh K |
9/15/2017 9:46 AM | |
Hello Dinesh, that was a good job Would you please open a ticket, at the Siemens Support, to have the developer debug the issue? That would be the best thing to do. Please provide them with all the necessary information to rebuild the issue there. Here you see, attached here, a form which you can fill out for this issue, to send it to the Support Dept. Also, it is a good practice to generate a template with that document, by entering the information which stays most of the times (like your SoldTo-#, operating system, if you use Citrix or not and so on). With that template, you will be faster from next time/ticket on. All the very best, SuperPippo AttachmentSupport_Ticket_Template_For_Customer.docx (377 Downloads) |
