10/15/2017 11:10 PM | |
Joined: 9/21/2016 Last visit: 2/25/2024 Posts: 15 Rating: (0) |
Dear expert i am facing same problem . our sensor module int. 20 ( 6SL 3055 OAAOO 5MAO) had damaged and we replaced same with next generation sm120 (ASE 33412837) but still drive fault have showed on HMI .We have sinamics s120 control unit cu 320 (6SL3040 OMAOO OAA1) . also we have connected CU320 with PG/PC VIA. starter ( FW - 4-5-1) and we found parameter error 404 . also we could't configure encoder . page showing DRIVE NAVIGATOR IS NOT ACTIVE .. so anyone can help me to how are we configure his encoder ? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/16/2017 12:57:13 PMNew subject after splitting |
10/19/2017 8:45 AM | |
10/20/2017 10:31 AM | |
Joined: 4/1/2013 Last visit: 11/29/2023 Posts: 59 Rating: (3) |
Hi! Have you tried uploading updated GSD file for your S120 CU320 module? this might solve your problem since you have new module which SM120. Just check link below this might help you. |
Last edited by: snemeis2015 at: 10/20/2017 10:32:09 AM"Never take advantage of others, but don't let others take advantage of you" |
