3/14/2018 1:45 PM | |
Posts: 3 Rating: (0) |
Hi, I am using Sinamics drives with S7-400 PLC's. I am using G120 ( Using CU230P-2DP V4.7), G130 (using CU320) and S120 (using CU320-2DP). Simatic manager V5.5 Proffessional and Drive ES-Starter V4.3 are used. I am able to access all the drives ( G130 & S120) with S7 online connection from my PC. But G120 drives are not able to access using S7 online with Drive ES ( and starter 4.3).G120 drives can be locally accessed with Device/S7USB connection. Can any expert suggest how to access G120 (CU230P-2DP V4.7) using S7 online from PG ? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 3/15/2018 1:09:35 PMNew subject after splitting |
3/21/2018 5:23 AM | |
Joined: 5/12/2006 Last visit: 9/20/2024 Posts: 22365 Rating: (3011)
Hell, and which FW Version of G120 you use? Christoph |
3/21/2018 6:36 AM | |
CU230P-2DP- V4.7.6 PLC CPU- 6ES7 416-2XN05-0AB0 / V5.3 CP - 6GK7 443-1EX11-0XE0 / V 2.5 |
