6/13/2018 9:06 AM | |
Joined: 11/29/2011 Last visit: 5/7/2024 Posts: 1358 Rating: (229) |
Hi, The issue is probably that you have more than 4 mastersystem configured by CiR. See the SIMATIC STEP7 V5.5 Modifying the System during Operation via CiR manual under chapter "6.1 CPU Response to Configuration Downloads in RUN Mode" page 48. You can read there among other things: "If more than four are found, the CPU will reject the modified configuration." You message is probably something to do with this. |
- What you read here, please check with manuals and your requirements. |
