4/9/2013 2:30 PM | |
Joined: 1/21/2011 Last visit: 1/23/2024 Posts: 162 Rating: (2) |
Dear all, I have problem in S7-300 software Redundancy while switching over the cpu sequences is not working all the output are get switch off. i have attached my program back up in which simple program of FC1 & FC2 but in switch over all sequences get stop ET200M act is switching over. i am new to software redundancy any sample SCADA Program Backup communicating with S7-300 Redundancy system. Thanks & Regards K.Jagan AttachmentMerittechcompactor.zip (618 Downloads) |
4/9/2013 3:09 PM | |
Posts: 515 Rating: (56) |
Hi Jagan, For SCADA redundant communication establishment,check the attached file.
AttachmentSWR_WINCC_english.pdf (816 Downloads) |
4/11/2013 8:31 AM | |
Posts: 153 Rating: (2) |
take one my ruuning back up and follow the rules as discussed aboveAttachmentSWR_RUNNING_ANIT.zip (862 Downloads) |
4/14/2013 3:19 PM | |
Hi is there any sample program back up of WINCC with the Software redundancy system . Regards K.Jagan
4/14/2013 3:57 PM | |
Hi jagan, Your backup cannot be retrieved since it has some errors. Did you verify that all your blocks contained in both the plc's are identical in online(not in offline state...).. Kindly find the attached file for your reference
AttachmentSoftware Redundancy.pdf (715 Downloads) |
5/7/2013 10:57 AM | |
Hi can you send me any SCADA back up running successfullyof S7-300 Redundancy system. Thanks & regards K.Jagan |
8/8/2018 3:51 AM | |
Posts: 8 Rating: (0) |
Hi Jagan, did you have successfully establish the PLC S7300 redundancy ? could you please share to me ? thank you Best regards, frisal |
