8/9/2018 9:22 PM | |
Joined: 3/14/2008 Last visit: 3/29/2024 Posts: 2059 Rating: (924)
Terminal bus disconnected or not properly inserted maybe? |
8/10/2018 4:05 AM | |
Joined: 9/9/2015 Last visit: 3/22/2024 Posts: 724 Rating: (264) |
Any pictures to show the issue? Offline = no server connection? Can you take a picture on the Simatic manager? What PG/PC are you connecting? To internal local? Can you check whether ethernet cable loosen? Is this previously working? |
Please give me 5 stars Rating if my post is helpful for you. :) |
8/10/2018 2:36 PM | |
Posts: 10 Rating: (0) |
Yes,previously working [snip] AttachmentScreenshots.zip (77 Downloads) |
Last edited by: deltavsiemens1000 at: 8/10/2018 2:37:06 PMLast edited by: deltavsiemens1000 at: 8/10/2018 5:27:15 PMLast edited by: Jen_Moderator at: 8/13/2018 8:42:11 AMAdded files as an attachment. Missing files are prohibited to open. |
8/12/2018 1:03 PM | |
Dear Deltavsiemens1000, 1. May I know how many stations do you have? 2. Your Engineering Station is OS Server? How many Servers do you have? Do you have clients? When your ES down, your client offline as well right? 3. Where your batch server installed? I saw the batch server application in your Tray icon. 4. You are currently pointing your PG/PC interface to CP1613 ISO. It means you are connecting to Plant bus (To PLC). If you would like to get the Wincc Online again, you need to establish the connection to OS servers. Are you able to ping the other stations? Under PG /PC interface, the proper configuration should be internal local. If not, you will not be able to link to Terminal us. Behind the ES station, you should have 3 cables. 2 cables is for Plant bus redundant. another one is a terminal bus, is to connect with servers and clients. If you want to get runtime data, the terminal bus needs to be good. Attached a screenshot on redundant CP in my engineering station. I configured my engineering station as a client station. |
