8/15/2018 9:22 PM | |
Posts: 4 Rating: (0) |
Hi, I have a similar problem with my CNC machine. The battery was broken and I have at now the 120202 "connection error". I have a different color light in my "SIMODRIVE" module (images light.jpg) Could you help me to solve this problem? Mi model is a Sinumerik 840D attach images with information Thanks a lot. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 8/16/2018 11:09:29 AMNew subject after splitting |
8/28/2018 7:43 PM | |
Hi, I've executed the solution and I have now a different light but we have the same screen error. Could you please help me to solve this? Attach new picture. |
9/6/2018 1:02 AM | |
Joined: 10/17/2007 Last visit: 4/17/2024 Posts: 3968 Rating: (340)
please check attached file. NC and PLC back up file is in your MMC103 HDD under folder "archive" You are responsible to find out the file name you want to download . if you are not sure, find out the nearest date one . IF you need help --you must take clean picture--when open "Services"--Data Manage--open "Archive" folder--taking picture--post here, I will suggest you to use which file Hope that helps Attachment810D NC PLC clear & reload proceduer.pdf (157 Downloads) |
If you like my comments please |
