10/17/2018 1:29 PM | |
Joined: 11/7/2016 Last visit: 1/29/2021 Posts: 4 Rating: (0) |
Hi, I have installed Simotion Scout V5.1. But I get this fault while its opening "error occurred while reading in the file: what should I do? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/18/2018 8:11:58 AMNew subject after splitting |
10/23/2018 2:04 PM | |
I have Windows 10 Pro 64bit. I get these error mesaages while I was installing ; Creating config files failed! Plesae check the log files for details; C:\ProgramData\Siemens\Autımation\Logfiles\Setup\mkcfgdb???_log.txt C:\ProgramData\Siemens\Autımation\Logfiles\Setup\hwakatimport???_log.txt There is no hwakatimport file on log files. ScoutLog file is on the attachment. AttachmentInstallScoutLog.txt (705 Downloads) |
6/17/2022 9:11 PM | |
Joined: 3/28/2019 Last visit: 6/18/2022 Posts: 4 Rating: (0) |
Hi The same problem did you found the solution? Thanks |
