10/21/2018 5:34 PM | |
Joined: 3/14/2008 Last visit: 4/24/2024 Posts: 2065 Rating: (926)
Hi, you have to set the scale from 0.0 tot 1.0. if this does not work, then you have to check the mode setting according to the hardware config. |
Last edited by: Oreca at: 10/21/2018 5:36:07 PMIf I could help you, you can use the RATE button. Thank you. |
