10/22/2018 9:53 AM | |
Joined: 4/24/2006 Last visit: 9/23/2024 Posts: 8742 Rating: (1168) |
Hello, Please have a look at the following link: Which memory cards can you use with an S7-300 CPU? Best regards, Wizard |
Joined: 5/12/2006 Last visit: 9/23/2024 Posts: 22369 Rating: (3012) |
Hello, here you find a overview which card you need: https://support.industry.siemens.com/cs/ww/en/view/19102565 for formating this cards you need a PG from Siemens or a external USB PÜrommer from Siemens. Regards Christoph |
10/22/2018 9:57 AM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1054)
hi, you can´t use the S7-400 MC in a S7-300. see following FAQ: Which memory cards can you use with an S7-300 CPU? hope this helps, regards, |
FCK WAR! |
10/22/2018 10:04 AM | |
Hello, not in a 315, but in a S7 318-2 DP it can be used Regards Christoph |
10/22/2018 10:06 AM | |
Posts: 4 Rating: (0) |
OK. Thanks a lot ! |
10/22/2018 2:47 PM | |
Joined: 7/9/2015 Last visit: 8/30/2024 Posts: 3943 Rating: (586)
Hi, before buying a new card, you should check if it will contain enough memory for your project. So please check the following FAQ before buying it. How can you determine the size of the load memory and main memory of a SIMATIC S7-300/400 CPU?Regards, Towome |
