11/19/2018 6:11 PM | |
Posts: 2 Rating: (0) |
Hola buen día compañeros Estimados por favor solicito su ayuda ya que tengo el cable de datos (CHINO) USB-PPI del PLC CPU 224 pero no cuento con el software de los controladores. Como puedo conseguir los drivers para poder utilizar este cable. agradezco su ayuda Fernando Avilés ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/20/2018 10:24:36 AMNew subject after splitting |
11/22/2018 8:23 AM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating: (818) |
Hello, hard to recommend some Driver (also again, is not clear to me why you need it), but you can look to this result of search Forum with PPI driver keywords: S7-200 PPI Driver Search Results You have 32 bit Win7? In case of x64, you need install MicroWin SP9, your SP3 isn't supported and in case of instalation you can have other problems, with functionality of course. Important question is, if you have your PPI adapter available in Win Device Manager, without errors and other statuses. In other side, with bought your adapter the previous owner can give you some CD with driver but with Chines products is not expected proper functionality. Here you need pay attention for important your OS compatibility. |
Last edited by: Duris_I at: 11/22/2018 8:25:38 AMLast edited by: Duris_I at: 11/22/2018 8:27:46 AMWith best regards... |
2/26/2022 6:31 AM |
Joined: 10/7/2012 Last visit: 1/11/2024 Posts: 1 Rating: (0) |
Do you enjoy correcting people? Only just try to help |
